NI 9263 onboard FIFO Size
Please let me know the onboard FIFO size of NI 9263 - simultaneous Analog output card. I did search in its specification but could not find any.
Sudha
(2,979 Views)
The NI 9263 does not have a FIFO.  The FIFO exists on whatever chassis you are using with the cartridge.  For example, the cDAQ-9172 has an analog output FIFO of 8191 samples (shared by all AO channels).  The chassis documentation lists this value under "Specifications".
(2,973 Views)
