Home
Community
Discussion Forums
Most Active Hardware Boards
Multifunction DAQ
Topic
Multifunction DAQ
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
NI 9265 module
NI 9265 module
damo59
Member
12-11-2007
05:49 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I have an NI 9265 module. It will output a current when using MAX but it will not work with the DAQ express vi.
The error is saying
Measurements: Not enough samples were written to satisfy the initial data transfer request condition
0
Kudos
Message
1
of 2
(2,996 Views)
Reply
Re: NI 9265 module
AdnanZ
Active Participant
12-12-2007
04:17 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Hi
Is it possible for you to post your code? How many samples are you outputting and at what rate? Changing the buffer size should fix the issue. Post your code so we can provide some suggestions to you.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
0
Kudos
Message
2
of 2
(2,981 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
