NI-9266 calibration
Hello all,
I would like to perform calibration a NI-9266 module plugged on last slot of my cDAQ-9185 chassis (fourth slot). When I execute "DAQmxGet9266CalAdjustPoints" function, I get nothing and it returns error code 51. Does anyone knows what does it mean?
Thanks in advance for your support.
James
(915 Views)
Did you follow the cal procedure?
https://www.ni.com/docs/de-DE/bundle/ni-9266-cal-pro/resource/4018495.pdf
Greetings from Germany
Henrik
LV since v3.1
(865 Views)
Yes I did. But instead of performing calibration with cDAQ-9178, 8-slot chassis, I use cDAQ-9185, 4-slot chassis.
Does anyone knows what does the error code "51" returned by DAQmxGet9266CalAdjustPoints, means?
James
(859 Views)
Hello everybody?
Do you have any ideas concerning my problem? Does anyone have facing this issue in the past?
Thanks in advance for your replies.
James
(803 Views)
Hello James,
So error code 51 means; invalid "null" method. (https://www.ni.com/docs/en-US/bundle/g-web-development/page/error-codes.html?srsltid=AfmBOopdHKJhvJj...)
I believe you can look into this link to get a "meaningful error message",
https://www.ni.com/docs/en-US/bundle/ni-daqmx-c-api-ref/page/daqmxcfunc/daqmxgeterrorstring.html
Please let me know if this helped or not!
(364 Views)
