NI 9327 excitation voltage
Hi all,
I am setting up load cells with NI 9327 with MATLAB. I used 4 load sensors which using all slots/channels.
ch4.ExcitationVoltage = 2.5;
Does max voltage for full bridge is 10V for NI 9327 ?
I got this error when the accumulative voltage >10V.
(184 Views)
The error states that the channels in a task must have the same excitation voltage.
Please try creating separate tasks for each channel that has a different excitation voltage.
Santhosh
Soliton Technologies
(161 Views)
Yes, it has to be same voltage per channel, the question is does all accumulative voltage need to <10V ?
(142 Views)
No, it is not sum of all excitation voltages. The excitation voltage is specified per channel and not total across all channels.
Santhosh
(125 Views)
