USB-6451 OEM Drawing Error
Definition for #5 and #6 seems to be wrong. Please confirm. Thanks.
(1,069 Views)
can you please post the real HW photo and cite why this drawing is incorrect?
Santhosh
Soliton Technologies
(1,053 Views)
Based on the board layout and the non-OEM version, I suspect that that #5 and #6 are listed backwards. #5 should be the AI portion and #6 should be AO and DIO.
I can not directly confirm as we do not have the OEM board in use. The labels on the non-OEM are definitely correct as we have utilized it.
(1,035 Views)
Thanks for looking into the matter. I noticed that the drawing conflicts with other information in the documentation, and I also physically verified the GND connection on an OEM board.
We came very close to producing a PCB based on the incorrect information. I shared the post primarily to alert NI to the discrepancy so it can be corrected.
(1,018 Views)
It looks like the manual was updated in the past few days, and the labelling of the OEM connectors was one of the fixes. Thanks for noticing and saying something!
(944 Views)
