NI - DAQ SCB-68
DAQ SCB-68 doesn’t appear in MAX Devices and Interfaces, and only the PCI shows up. The current versions being used are LabVIEW 2011 and MAX 5.0. The error message while running a VI is error - 201003. Any tips to resolve this?
(835 Views)
SCB-68 is a terminal block. It will not show up in the NI MAX.
Only the PCI DAQ device will show up.
Try the steps in Error -201003 When I Run My Task in MAX or LabVIEW
Make sure you have installed a compatible NI-DAQmx version. See Determine the Version of NI Software Installed on My Computer and NI-DAQmx and LabVIEW Compatibility
https://tmesystems.net/
(809 Views)
