‎08-09-2006 03:54 PM
I am translating an application that was originally written in LabWindow for DOS (in the timeframe of 1993 to 1996) into LabVIEW 7.1 with Traditional NI-DAQ version 7.4.1. I am using a PCI-MIO-16XE-50 to replace a AT-MIO-16XE-50. Can you tell me which LabVIEW Traditional NI-DAQ VI should be used to replace the function SCXI_SCAN_Setup?
Thank you,
Cherie
‎08-09-2006 04:20 PM
I also need help finding a replacement for the function SCXI_MuxCtr_Setup.
Thank you,
Cherie
‎08-10-2006 08:30 PM
‎08-11-2006 11:41 AM
Thanks for replying.
I do not have the option of re-writing the application because 90% of the work is already done (although I totally agree that a re-write is the best way to go). I found out that the original functions are still available in the nidaq32.dll library and was able to access them through a call library function node.
Cherie
