NI DAQPad-6508 intermittently becoming inaccessible via LabVIEW
We have two identical test systems that have been using the NI DAQPad-6508 for some years now.
Recently both systems have started showing the same problem - the 6508 is becoming inaccessible via LabVIEW.
Closing LabVIEW, power cycling the 6508 and then re-running the application fixes the problem.
This then lasts anything from 10 minutes to a day or so before the problem reoccurs.
One of the systems is showing the problem much more than the other - some 80% more.
The system is running on XP with the following software:
NameVersionDescriptionPath
CVI Run-Time7.1.1.350CVI Run-Time engineC:\WINDOWS\system32\CVIRTE.DLL
NI-DAQ7.4.1f4Data Acquisition SoftwareC:\Program Files\National Instruments\NI-DAQ
NI-DAQmx8.0.0f0NI-DAQmx Device DriverC:\Program Files\National Instruments\NI-DAQ
NI-488.2 Software2.24Controller & Analyzer SoftwareC:\Program Files\National Instruments\NI-488.2
LabVIEW8.0.1Graphical Programming for Measurement & InstrumentationC:\Program Files\National Instruments\LabVIEW 8.0\labview.exe
Advanced Signal Processing Toolkit7.5.0Advanced Signal Processing ToolkitC:\Program Files\National Instruments\LabVIEW 8.0
Database Connectivity Toolset1.0.132Database Connectivity ToolsetC:\Program Files\National Instruments\LabVIEW 8.0
Express VI Development Toolkit1.0Express VI Development ToolkitC:\Program Files\National Instruments\LabVIEW 8.0
Internet Toolkit6.0.0Internet ToolkitC:\Program Files\National Instruments\LabVIEW 8.0
PID Control Toolset6.0PID Control ToolsetC:\Program Files\National Instruments\LabVIEW 8.0
Sound and Vibration Toolset4.0.49153Sound and Vibration ToolsetC:\Program Files\National Instruments\LabVIEW 8.0
VIAnalyzer Toolkit1.1VIAnalyzer ToolkitC:\Program Files\National Instruments\LabVIEW 8.0
LabVIEW Run-Time6.1LabVIEW Run-Time EngineC:\Program Files\National Instruments\Shared\LabVIEW Run-Time\6.1
Measurement & Automation Explorer4.0.0.3010Use Measurement & Automation Explorer to manage your National Instruments products and servicesC:\Program Files\National Instruments\MAX\nimax.exe
NI-USI1.0.2NI Universal Storage InterfaceC:\Program Files\National Instruments\Shared\USI
NI-PAL Software1.10.0f0NI-PAL Library for WindowsC:\WINDOWS\system32
NI Spy2.3.0.49152Monitors National Instruments API callsC:\Program Files\National Instruments\NI Spy\NISpy.exe
TestStand3.5Complete Test Executive EnvironmentC:\Program Files\National Instruments\TestStand 3.5\bin\seqedit.exe
NI-VISA3.4Virtual Instrument Software ArchitectureC:\WINDOWS\system32\visa32.dll
visa32.dll3.4.0.49152VISA LibraryC:\WINDOWS\system32\visa32.dll
NiVisaServer.exe3.4.0.49152Remote NI-VISA ServerC:\VXIPNP\WinNT\NIvisa\NiVisaServer.exe
NIvisaic.exe3.4.0.49152VISA Interactive Control UtilityC:\VXIPNP\WinNT\NIvisa\NIvisaic.exe
LabVIEW Run-Time7.0LabVIEW Run-Time EngineC:\Program Files\National Instruments\Shared\LabVIEW Run-Time\7.0
LabVIEW Run-Time7.1LabVIEW Run-Time EngineC:\Program Files\National Instruments\Shared\LabVIEW Run-Time\7.1
LabVIEW Run-Time8.0.1LabVIEW Run-Time EngineC:\Program Files\National Instruments\Shared\LabVIEW Run-Time\8.0
The device remains within device manager and MAX.
I have tried removing the driver and then letting it re-load after re-starting the PC - no luck.
Any ideas what may be causing this problem?
Your help would be appreciated.
Message Edited by AndyVessey on 12-03-2009 03:49 PM
(3,689 Views)
Hi Andy,
Did the post muks linked help at all?
Owen.S
(3,646 Views)
Hi
Thanks muks for the links and thank Owen.S for the question.
The links mainly seem to indicate that the unit mustn't run from USB bus power and should be powered via an external PSU.
This morning I removed the cover from the unit and measured the DC getting to the PCB via the external DC socket. 15VDC is on the PCB and the connection seems good/solid.
We are restarting the production line on Wednesday and so I will try a few more ideas from the links ect early this week.
Thanks again
Andy
(3,642 Views)
Yeah keep us updated....:smileywink:
(3,639 Views)
