12-03-2009 09:46 AM - edited 12-03-2009 09:49 AM
We have two identical test systems that have been using the NI DAQPad-6508 for some years now.
Recently both systems have started showing the same problem - the 6508 is becoming inaccessible via LabVIEW.
Closing LabVIEW, power cycling the 6508 and then re-running the application fixes the problem.
This then lasts anything from 10 minutes to a day or so before the problem reoccurs.
One of the systems is showing the problem much more than the other - some 80% more.
The system is running on XP with the following software:
| Name | Version | Description | Path |
| CVI Run-Time | 7.1.1.350 | CVI Run-Time engine | C:\WINDOWS\system32\CVIRTE.DLL |
| NI-DAQ | 7.4.1f4 | Data Acquisition Software | C:\Program Files\National Instruments\NI-DAQ |
| NI-DAQmx | 8.0.0f0 | NI-DAQmx Device Driver | C:\Program Files\National Instruments\NI-DAQ |
| NI-488.2 Software | 2.24 | Controller & Analyzer Software | C:\Program Files\National Instruments\NI-488.2 |
| LabVIEW | 8.0.1 | Graphical Programming for Measurement & Instrumentation | C:\Program Files\National Instruments\LabVIEW 8.0\labview.exe |
| Advanced Signal Processing Toolkit | 7.5.0 | Advanced Signal Processing Toolkit | C:\Program Files\National Instruments\LabVIEW 8.0 |
| Database Connectivity Toolset | 1.0.132 | Database Connectivity Toolset | C:\Program Files\National Instruments\LabVIEW 8.0 |
| Express VI Development Toolkit | 1.0 | Express VI Development Toolkit | C:\Program Files\National Instruments\LabVIEW 8.0 |
| Internet Toolkit | 6.0.0 | Internet Toolkit | C:\Program Files\National Instruments\LabVIEW 8.0 |
| PID Control Toolset | 6.0 | PID Control Toolset | C:\Program Files\National Instruments\LabVIEW 8.0 |
| Sound and Vibration Toolset | 4.0.49153 | Sound and Vibration Toolset | C:\Program Files\National Instruments\LabVIEW 8.0 |
| VIAnalyzer Toolkit | 1.1 | VIAnalyzer Toolkit | C:\Program Files\National Instruments\LabVIEW 8.0 |
| LabVIEW Run-Time | 6.1 | LabVIEW Run-Time Engine | C:\Program Files\National Instruments\Shared\LabVIEW Run-Time\6.1 |
| Measurement & Automation Explorer | 4.0.0.3010 | Use Measurement & Automation Explorer to manage your National Instruments products and services | C:\Program Files\National Instruments\MAX\nimax.exe |
| NI-USI | 1.0.2 | NI Universal Storage Interface | C:\Program Files\National Instruments\Shared\USI |
| NI-PAL Software | 1.10.0f0 | NI-PAL Library for Windows | C:\WINDOWS\system32 |
| NI Spy | 2.3.0.49152 | Monitors National Instruments API calls | C:\Program Files\National Instruments\NI Spy\NISpy.exe |
| TestStand | 3.5 | Complete Test Executive Environment | C:\Program Files\National Instruments\TestStand 3.5\bin\seqedit.exe |
| NI-VISA | 3.4 | Virtual Instrument Software Architecture | C:\WINDOWS\system32\visa32.dll |
| visa32.dll | 3.4.0.49152 | VISA Library | C:\WINDOWS\system32\visa32.dll |
| NiVisaServer.exe | 3.4.0.49152 | Remote NI-VISA Server | C:\VXIPNP\WinNT\NIvisa\NiVisaServer.exe |
| NIvisaic.exe | 3.4.0.49152 | VISA Interactive Control Utility | C:\VXIPNP\WinNT\NIvisa\NIvisaic.exe |
| LabVIEW Run-Time | 7.0 | LabVIEW Run-Time Engine | C:\Program Files\National Instruments\Shared\LabVIEW Run-Time\7.0 |
| LabVIEW Run-Time | 7.1 | LabVIEW Run-Time Engine | C:\Program Files\National Instruments\Shared\LabVIEW Run-Time\7.1 |
| LabVIEW Run-Time | 8.0.1 | LabVIEW Run-Time Engine | C:\Program Files\National Instruments\Shared\LabVIEW Run-Time\8.0 |
The device remains within device manager and MAX.
I have tried removing the driver and then letting it re-load after re-starting the PC - no luck.
Any ideas what may be causing this problem?
Your help would be appreciated.
12-04-2009 01:57 AM
12-07-2009 04:59 AM
Hi Andy,
Did the post muks linked help at all?
12-07-2009 05:36 AM
Hi
Thanks muks for the links and thank Owen.S for the question.
The links mainly seem to indicate that the unit mustn't run from USB bus power and should be powered via an external PSU.
This morning I removed the cover from the unit and measured the DC getting to the PCB via the external DC socket. 15VDC is on the PCB and the connection seems good/solid.
We are restarting the production line on Wednesday and so I will try a few more ideas from the links ect early this week.
Thanks again
Andy
12-07-2009 05:43 AM
