NI DAQmx 8.0 API for Suse 10 and LV 7.1
Hallo there,
I am using Suse Linux 10 with LabVIEW 7.1 and DAQmx 8.0.
My problem is that when I'm opening a blank VI I can't find the option "Measurement I/O" in order to use the DAQmx API.
I can't also find the DAQmx under LAbVIEW->Tools.
However DAQmx recognizes the device I've installed (PCI 6036E) and it seemed that DAQmx installation proceeded correctly
Any help appreciated. Thank you in advance....Smiley Happy
(3,296 Views)
Hi Jim-
NI-DAQmx for Linux only supports LabVIEW 8.0 and later.  In order to use NI-DAQmx in Linux you will need to upgrade your LabVIEW version (or alternatively program in C/C++).
Hopefully this helps-
Tom W
(3,286 Views)
Tom, first of all, I would like to thank you for your reply which is really helpful.
If i can't upgrade to LV8.0,Is there a version of traditional NI DAQ i could use for linux??
If so,you would suggest to work this way or to work LV in WIndows?
(3,284 Views)
Hi Jim-
No, Traditional NI-DAQ never supported Linux.  I would recommend NI-DAQmx for all new development projects regardless of which O/S you are developing for.  If you have access to LabVIEW 7.1 or later for Windows you can use NI-DAQmx.  The most recent version (is linked here.
Thanks-
Tom W
(3,279 Views)
