NI ELVIS II+ builtin DAQ device specifications
Can anyone share the hardware specifications of the built in Multifunction DAQ device incorporated into NI ELVIS II+ board?
(4,739 Views)
Hi Anushaas,
Please find the link below helpful
http://www.ni.com/pdf/manuals/372590b.pdf
Let us know if this was what you were looking for or something else, and what kind of application you plan on pursuiing which requires such details of hardware specs, in detail.
Cheers,
Rao
NI INDIA AE
(4,720 Views)
I was looking for thr the specifications of DAQ card used in NIELVIS II+.
I needing to specify it while publishing my work done that is done on the NI platform
(4,717 Views)
Hi Anushaas,
"The specifications in this document refer to both the NI ELVIS II and the NI ELVIS II+ unless otherwise noted. These specifications are typical after a 30 minute warm-up time, at 25 °C, unless otherwise noted."
This is the first line of the link of the document put in my previous post.
Cheers.
Rao
NI INDIA AE
(4,711 Views)
