rearm time of PCI-6111 compare to USB-6251
Hi
We have been using USB-6251 for voltage acqusition via analog input.
Typcial set up is as below.
- 1.25 MSample/sec
- 400 samples/event
- Window trigger using the analog input (threshold 20~40 mV)
- test duration about 5 min.
-number of events: more than 1,000 throughour the test.
However as we found the rearm time of USB-6251 is long (~0.03 sec), we are planning to get a new DAQ board or digitizer.
The one we are interested in is PCI-6111.
Is there any way we can know how long the rearm time would be with PCI-6111 when test conditions is identical?
I wanted to get the numbers from its spec but couldnt find the number.
Thank you!
(3,850 Views)
Hello skim151,
My name is Randy and I am an Applications Engineer at National Instruments. Can you please sent me a private message with your contact information that way I will create a Service Request and handle this issue by email or phone call.
I will like to know more about your application before give a recommendation.
Randy @Rscd27@
(3,832 Views)
Hi Randy
I have sent you a message with my email adress.
I will wait for your reply.
(3,763 Views)
