Use NI-cDAQ 9174 through a wireless network
I am participating in a research group and we are building robots and using NI-cDAQ 9174 to interface with them.  We can easily use the USB connection to the computer to program the robots, however we want to go through a wireless network instead.  We've installed a D-link DIR-601-A1 wireless router onto the robot and have a USB to ethernet converter that we want to go from the cDAQ to the router.  Our desktop connects to the Router, NI-MAX sees the network, however NI-MAX does not see any devices connected to it, even though we have the cDAQ going into the router.  I notice the "ready" indicator is not acitivated on the cDAQ when plugged into the router, unlike when its plugged directly into the desktop computer.
(4,100 Views)
Hi Grubish,
Unfortunately this isn’t a tested or supported configuration for the USB cDAQ. I have a hunch that this might not be working because you are trying to transfer from a USB protocol to an Ethernet protocol and the USB cDAQ is not a host. Therefore, there is no software component to translate this protocol shift to the host computer.
Have you looked into our Ethernet cDAQs (https://www.ni.com/en-us/support/model.cdaq-9184.html)? It sounds like this is more of what you would need for this application. If you’re interested in looking into this more please reach out, let us know, and we I can get you in contact with the right person.
A Johnson
(4,071 Views)
Hi Johnson,
Thank you for the response.  Unfortunately for our situation I dont believe we have the funds available to purchase the ethernet equipped cdaq.  We are involved in a robotics club run by our professor at the University of Wisconsin-Eau Claire.  I'll let him know about our current situation tomorrow.
Thank you again,
Jason
(4,067 Views)
