‎05-30-2007 09:40 AM
‎05-31-2007 07:10 PM
‎06-01-2007 09:58 AM
‎06-01-2007
11:10 AM
- last edited on
‎07-15-2025
08:52 AM
by
Content Cleaner
Hi kp-
You'll need to update your version of NI-DAQmx Base in order to add LabVIEW 8.0 support. NI-DAQmx Base 2.2 is the current version, and it supports LabVIEW versions 8.0.x and 8.2.x. If you need to maintain support for LabVIEW 7.1 as well as add support for LabVIEW 8.0 then you should use NI-DAQmx Base 2.0.
Hopefully this helps-
‎06-01-2007 01:51 PM
