NI PCI-4474 data acquisition ContAccelSamps-IntClk-AnlgStart.c
I need to acquire the acceleration data with my NI PCI-4474 connected with an accelerometer.
The PCI-4474 is correctly configured under OpenSuse 11.3. This is the nilsdev output:
NI PCI-4474: "Dev1"
I modified the ContAccelSamps-IntClk-AnlgStart.c in the Nidaqmx documentation examples:
* ANSI C Example program:
*    ContAccelSamps-IntClk-AnlgStart.c
#include <stdio.h>
#include <stdlib.h>
#include <NIDAQmx.h>
#define DAQmxErrChk(functionCall) if( DAQmxFailed(error=(functionCall)) ) goto Error; else
int32 CVICALLBACK EveryNCallback(TaskHandle taskHandle, int32 everyNsamplesEventType, uInt32 nSamples, void *callbackData);
int32 CVICALLBACK DoneCallback(TaskHandle taskHandle, int32 status, void *callbackData);
int main(void)
	int32       error=0;
	TaskHandle  taskHandle=0;
	char        errBuff[2048]={'\0'};
	// DAQmx Configure Code
	DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
	DAQmxErrChk (DAQmxCreateAIAccelChan(taskHandle,"Dev1/ai0","",DAQmx_Val_PseudoDiff,-100.0,100.0,DAQmx_Val_AccelUnit_g,50,DAQmx_Val_mVoltsPerG,DAQmx_Val_Internal,0.004,NULL));
	DAQmxErrChk (DAQmxCfgSampClkTiming(taskHandle,"OnBoardClock",10000.0,DAQmx_Val_Rising,DAQmx_Val_ContSamps,1000));
	DAQmxErrChk (DAQmxCfgAnlgEdgeStartTrig(taskHandle,"Dev1/ai0",DAQmx_Val_Rising,30.0));
	DAQmxErrChk (DAQmxSetAnlgEdgeStartTrigHyst(taskHandle, 10.0));
	DAQmxErrChk (DAQmxRegisterEveryNSamplesEvent(taskHandle,DAQmx_Val_Acquired_Into_Buffer,1000,0,EveryNCallback,NULL));
	DAQmxErrChk (DAQmxRegisterDoneEvent(taskHandle,0,DoneCallback,NULL));
	// DAQmx Start Code
	DAQmxErrChk (DAQmxStartTask(taskHandle));
	printf("Acquiring samples continuously. Press Enter to interrupt\n");
	getchar();
Error:
	if( DAQmxFailed(error) )
		DAQmxGetExtendedErrorInfo(errBuff,2048);
	if( taskHandle!=0 ) {
		// DAQmx Stop Code
		DAQmxStopTask(taskHandle);
		DAQmxClearTask(taskHandle);
		printf("DAQmx Error: %s\n",errBuff);
	printf("End of program, press Enter key to quit\n");
	getchar();
	return 0;
	int32       error=0;
	static int  totalRead=0;
	int32       read=0;
	float64     data[1000];
	/* Change this variable to 1 if you are using a DSA device and want to check for Overloads. */
	int32       overloadDetectionEnabled=0;
	bool32      overloaded=0;
	char        overloadedChannels[1000];
	// DAQmx Read Code
	DAQmxErrChk (DAQmxReadAnalogF64(taskHandle,1000,10.0,DAQmx_Val_GroupByScanNumber,data,1000,&read,NULL));
	if ( overloadDetectionEnabled )
		DAQmxErrChk (DAQmxGetReadOverloadedChansExist(taskHandle,&overloaded));
	if( read>0 ){
		printf("Acquired %d samples. Total %d\r",read,totalRead+=read);
		for(int i=0; i< read; i++){
			printf("%f\n", data[i]);
	if( overloaded ) {
		DAQmxErrChk (DAQmxGetReadOverloadedChans(taskHandle,overloadedChannels,1000));
		printf("Overloaded channels: %s\n",overloadedChannels);
	fflush(stdout);
Error:
	if( DAQmxFailed(error) ) {
		// DAQmx Stop Code
	return 0;
	int32   error=0;
	// Check to see if an error stopped the task.
	DAQmxErrChk (status);
Error:
	return 0;
Unfortunately the program never calls the EveryNCallback callback...
Why the board can't acquire and print any data?
(3,074 Views)
I solved the problem commenting the following code:
// DAQmxErrChk (DAQmxSetAnlgEdgeStartTrigHyst(taskHandle, 10.0));
(3,066 Views)
