simulated NI PCI-6221 daq
I have to create some program, which uses Simulated NI PCI-6221 card. I've found a problem, when I wanted to create some constant signal on one analog output and then read this signal using one of analog inputs. Is it possible anyway, to do such thing with simulated cards ?
(3,288 Views)
Hi!
I am afraid that it is not posible to read signal on AI in the way that you try.
If you have real hardware, you should connect physically AO on AI. In simulated devies it is not posible.
S.P.
(3,272 Views)
