NI PCI-6251 not recognized correct in MAX
i've just installed 2 PCI-6251-DAQ-Cards in a industrial pc and it seems, that they both aren't recognized correct by the NI-MAX.
Here is what i see in MAX:
I've installed the NI-DAQmx-Drivers which came with the cards (Version 8.6) before inserting the cards into the slots. After inserting the cards & starting windows again, the automatic driver-installation of windows seemd to work just fine (no error-message, ...).
The MAX shows 3 Devices because i've allready tried to move the 1. card to another free slot in my computer...
I'm allready downloading the new NI-DAQmx (Version 9.0) but the 1.3 gb still need some time, so my question is now, if you have any idea, what else i can try beforehand?
My second question is the following:
The cards have a connection of which i don't exactely know what it's worth for and how i can plug it in (the black one in the middle of the image):
The installation-manual that came with the card says something about a additional power-source and that one should plug it to a disc-connector or some other source (for better analog performance, i think) what i don't really understand because ide-disc-connectors in a pc definitely don't fit into this plug (1 pin too much in the middle...). Can someone explain this to me?
Thank you in advance for your help!
mik
Message 1 of 8
(4,456 Views)
Hi
installing the latest DAQmx driver is a good idea. Otherwise you can try a different pc or different slots for your boards.
The second question is described here:
 http://www.ni.com/pdf/manuals/371022k.pdf (page 41)
So you won't need it for the beginning.
Regards
DianaS
Message 2 of 8
(4,430 Views)
Thanks for your answer. I've allready tried the new driver. Different slots also. Result is still the same. Unfortunately i don't have a second pc to test...
Message 3 of 8
(4,424 Views)
What pc is it?
Regards
DianaS
Message 4 of 8
(4,422 Views)
It's a ROCKY-4786EVG-RS-R40 in a RACK-360GW (Chassis)
Message 5 of 8
(4,420 Views)
Please check the following steps:
http://digital.ni.com/public.nsf/allkb/E8CAFBC41A7B9BF086256D3C00650011
Regards
DianaS
Message 6 of 8
(4,417 Views)
Message 7 of 8
(4,416 Views)
Message 8 of 8
(4,414 Views)
