coexisting NIDAQmxBase.h and NIDAQmx.h?
I have a situation were I need to use both nidaqmx and nidaqxm-base, using plain C/C++ and linux. There is an issue that they have identical defines (In my case __CFUNC and more ..) and declarations (‘typedef uInt32* TaskHandle’). I realize that they share the same code base so the reason is obvious, but what to do in order to create safe code?
Best Regards and in need of linux mx lib with support of NI-6009 to remove NIdaq-mx base once and for all
Leif Adelöw
Message 1 of 1
(2,949 Views)
