Multifunction DAQ
NI-PCI6221 AND scB-68 anolog input issue
Accepted by jinwei
Yes, you are right, I just get about 0.5 resisteance, when i measure in short circuit, but question is the vules fluctuates up and down,  i am confusion. if just  offset , it is ok, but  I try to figure out.. tired...
Thank you.
Message 11 of 13
(1,267 Views)
Hi jinwei,
As S_Hong said before the accuracy of your measurement will depend on many factors. The accuracy is not an offset value the signal will be shifted to, but a certain amount that the signal can vary within. Have a look at this Developer Zone for more information about Accuracy and the System Environment. I hope this is helpful,
Ana P
Applications Engineer
Message 12 of 13
(1,249 Views)
I GOT IT!
Message 13 of 13
(1,225 Views)
