NI PXI-1033 with DMM PXI 4065 strange problem !?
Hi all,
I have a NI PXI-1033 Chassis together with NI PXI 4065 DMM and NI PXI 6514 device.
The problem that I have is very annoying. When I restart my computer or install a new NI feature, the two NI PXI-6514 and PXI 4065 are no longer available as shown at the picture attached and I have to reinstall the drivers in order they to function properly. Why is this happening? Is it normal?
I will appreciate every help because it is urgent and important. Thank you!
Best,
Iliya Gurov
(3,298 Views)
first we should concentrate on the DAQmx driver and the Measurement&Automation Explorer.
The discussion below describes exactly the same problem:
http://forums.ni.com/ni/board/message?board.id=170&message.id=429448&requireLogin=False
Please try to repaire the MAX. What version are you using?
Best regards
Rüdiger
(3,277 Views)
