NI USB-6008 Self Test Error
Hi there,
I have encountered a problem on configuring the NI USB-6008 device. The NI-DAQmx ver 8.3 is installed in a Windows XP.
Error:
The device self test has failed. The error repot from the device driver is as follows:
Error -88302 occurred at Self Test
Possible Reason(s):
An internal error occurred.
The error above came up when it comes to self test.The LED light on the device is blinking non-stop. When I right clicked on the device in MAX, "Test Panels", "Delete", "Properties" and "Self-Calibrate" option are not available. The same error will come up if "Reset Device" is clicked. I have looked for the solutions in the forum but I can't get to the configuration settings as mentioned in this solution: http://digital.ni.com/public.nsf/websearch/19E7993CF8366EED8625764200771C68?opendocument&Submitted&&...
Is there any other ways to solve the error?
(4,806 Views)
That version is 8 years old. Have you tried something newer? What application development software are you using?
(4,798 Views)
Nope. This ver of installer is given by the manager and I am trying to install it with the NI USB-6008. I'm not sure on the application.
(4,794 Views)
You don't know whether the program will use c, LabVIEW, .NET, or something else?
Have your manager get on the forum or tell him you need to try a driver that is more recent.
(4,789 Views)
