install the hardware
I would like to install the #6043E  PCI card and VI logger software origionally designed for windows XP onto Windows 8.  I assume a software update and new DAQ drivers are available but can't find VI logger on the NI website.
(5,275 Views)
Accepted by topic author OmarS
VI Logger has not been supported for a few years and never on Windows 8. You would want SignalExpress but I can't find any record of a 6043 device.
(5,269 Views)
Thanks for the quick reply. It looks like mistyped the model number, it is PCI-6034E. Is the latest version of NI-DAQmx (ver 14.2) needed for the windows 8 PCI card driver or is the driver included with this SignalExpress program? I went to http://www.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/catnav:du,n8:3478.41.181.5495,s... and tried to download http://www.ni.com/download/ni-daqmx-14.2/5046/en/ but nothing happens. Assuming I can find a way to download the NI-DAQmx software is this software needed and is there any additional licensing cost for using it? Thank you in advance.
(5,260 Views)
There seems to be problem with the web site. I can't view the download page either. Yes, you need DAQmx and there is no charge for it. When the site is back up, verify that your device is supported.
(5,254 Views)
The download page is back up and your card is listed as supported.
(5,235 Views)
Thank you for your help!
(5,230 Views)
It would have been polite to mark my answer as the solution, not your thank you.
(5,223 Views)
