03-19-2012 08:38 AM
We are wondering if it is possible to connect the AO0 to the AO1 as a serial voltage source that generates 5 + 5 Volts?
The datasheet does not say do or dont, but it says they are independent.
Worst case scenario being short circuiting one of the outputs if the ground is common?
Solved! Go to Solution.
03-19-2012 08:41 AM
