NI USB 6008 analog outputs in serial to generate 10 V
We are wondering if it is possible to connect the AO0 to the AO1 as a serial voltage source that generates 5 + 5 Volts?
The datasheet does not say do or dont, but it says they are independent.
Worst case scenario being short circuiting one of the outputs if the ground is common?
(2,900 Views)
