NI USB-6210 issue with syntax
Hello All,
I have an issue with syntax when trying to read data from USB-6210
I am trying to refer to physical channels from 10 to 15, so I use
Dev4/ai10:15
However debug mode shows me that a task created from this string is Dev4/ai10:*
I've tried also to write Dev4/ai10,Dev4/ai11 and Dev4/ai10:Dev4/ai15 and the same It only shows Dev4/ai10:*
I've chosen in Read Block Multiple Chan, One Sample for reading data, and Clock is in continous mode, channels are RSE.
Maybe somebody can help me with this, would be grateful. Ill provide code if necessary.
Best Regards,
Mateusz
(2,274 Views)
Issue solved, topic can be closed.
(2,248 Views)
