NI USB-6251 Sampling Rate Problem
I am using a piezo sensor with a NI USB-6251 to obtain voltage/time data. I am, however, only able to obtain a maximum of one reading every 0.02s.
I’ve tried using the same sensor and code with a BNC-2120/ PCI-6221 set-up and have been able to get a much better rate.
Does anyone have some advice on how to increase the rate with the NI USB-6251?
Thanks.
(4,010 Views)
Have you tried the provided examples ?
How about posting your vi?
Greetings from Germany
Henrik
LV since v3.1
(4,002 Views)
