NI USB-6259 BNC external Calibration
I have a NI USB-6259 BNC that I'm hoping to externally calibrate the voltage inputs and voltage outputs.
I've been looking through the calibration procedure using NI-DAQmx. However it doesn't seem to have anything to say about the BNC version of the 6259 in terms of where to connect the voltage calibrator, and it talks about connecting to AI8 which doesn't seem to be on my device (at least not the front panel, could be internal).
So I have two questions:
1) Can I do an external calibration on this device? If so where am I connecting the calibrator and DMM?
2) It seems that I can use the DAQmx calibration VI's so is there an example of how that would work?
Tom
Message 1 of 1
(2,219 Views)
