cdaq-9171 and DAQmx API
I have build my own program with .NET Daqmx API to use DAQ devices. It works, I can create and launch tasks for Analog/Digital input/output.
I just tried to plug a cDAQ 9171. It is detected, but device->GetPhysicalChannels() will always return an empty array, so I cannto do anything with it.
Hwoever, I I launch DAQ express, I can see that the device works correctly, and that voltage is detected on the pins.
How can I detect the Analog Input channels on that devices in my code ? Why does it behave differently than PCI or USB boards ?
[edit]
If I force the channels to be named cDaq1Mod1/ai0, it just works. So the question is : whay does dthe device does not report such channel names ?
(3,199 Views)
I found the list of channels for the device :
http://zone.ni.com/reference/en-XX/help/370466AH-01/mxdevconsid/cdaqphychannels/
Should I hard-code it ? Why is it not reported correctly by the Daqmx API ?
(3,163 Views)
Accepted by topic author pierrechatelier
I have found it.
I did not understand that the CDAQ was a wrapper around "ChassisDevices". I can get all information by querying ChassisModuleDeviceNames and opening the sub devices.
(3,159 Views)
