NI USB-6341 getting disconnected to windows intermittently
Hi.
I would really appreciate any technical insight regarding my issue.
I have a NI-USB 6341 connected to an Analyzer via a windows 7 PC.
It intermittently disconnects and causing issue with my measurement.
Frequency of disconnection is unpredictable.
And the only way to get it connected is by restting power to the device.
One question, do i need to activate or register my device?
The system is standalone and is not permitted to be connected to the web.
Thanks in advance.
(3,188 Views)
The phenomenon is not related to activation and register problem.
You don't have to do any registration to use the device.
Do you connect the device to your PC directly? Or via USB hub?
Do you supply enough power to the device? Is Your PC suspend mode?
Certified LabVIEW Developer
GCentral
(3,162 Views)
Hi Emboar.
Thanks for clarifying the thing about registration/activation.
Regarding your question, yes it is directly connected to the PC USB port. (The PC is Lenze CS 5800 IPC.)
Power to the NI is supplied via power supply block that came with the device.
PC screensaver/power saving option is disabled. USB selective suspend is also disabled.
Is there any way check or any logs to tell me how frequent it connects/disconnects to the PC?
(3,154 Views)
I find some free tool to monitor USB connect/disconnect status.
USBLogView v1.25
When you found the device was disconnected, was power LED turned on?
GCentral
(3,149 Views)
Hi Batino
Do you fixed your problem. Could you share how do you fix this issue? Now we have the problem as same as yours.  PC win7 32 bit;When this card disconnected, the power LED is turn on normal, but the other LED blinked. By the way. when our program prompt error. The PC system always show detected new device about this card.
(2,768 Views)
This could also have something to do with how Windows handles the USB power.
Please check if the solution provided on another post applies here, https://forums.ni.com/t5/Instrument-Control-GPIB-Serial/VISA-write-error-Arduino-after-hours-of-exec...
Santhosh
Soliton Technologies
(2,734 Views)
