NI USB driver loses device over long period (1 week) - error -50405
Hello All,
I've posted a reply to this issue in a separate forum.
Please look here for more info.
-Justin
Message 41 of 45
(2,874 Views)
<deleted>
Message Edited by mattmaka on 10-23-2009 11:49 AM
Message 42 of 45
(2,714 Views)
I had been getting the same type error with a USB cDAQ 9172 utilizing a 9481 relay module. The error was very intermittent. I had found that the power supply voltage to the cDAQ 9172 chassis was dropping down to extremely low levels at times. I corrected the issue and this appears to have solved the problem.Smiley Happy
Message 43 of 45
(2,388 Views)
just read your post. I also encountered problems with a NISE-100 computer. Same type: fanless and low power consumption.
Problems like windows instability occurs together with USB DAQ-Devices like USB-6008 or USB-6210.
Did you solve yours in the past one and a half years?
Regards Markus
Message 44 of 45
(2,210 Views)
No. I solved it by getting a Netbook running Windows 7. Only a slightly higher power consumption and a much better computer.
Message 45 of 45
(2,156 Views)
