Multifunction DAQ
NI USB6008 + NiDaqMxBase + Linux simultaneous analog input
Hello!
My setup:
NI USB6008
NiDaqMxBase
Linux OpenSUSE 11.0 on netbook Toshiba NB200
I need to measure 4 AI channels 5 times a second.
I do:
create AI0 ... AI3 = DAQmxBaseCreateAIVoltageChan( taskHandle, chan, "", DAQmx_Val_RSE, min, max, DAQmx_Val_Volts, NULL )
do
   start  AI0 - read AI0 - stop AI0 = DAQmxBaseStartTask(thAI0) - DAQmxBaseReadAnalogF64(thAI0... - DAQmxBaseStopTask(thAI0);
   start  AI3 - read AI3 - stop AI3
while true
One do-while loop takes ~ 1 second
The question: Is there a way to speed up the procedure?
Vadim.
(3,835 Views)
Hello Vadim,
To speed up your program I recommend setting your acquisition to do a continiuos read, as suppose to starting the task, reading one sample and ending the task, where most of your delay is likeely occurring.  Look in the following folder \\...National Instruments\NI-DAQmx Base\Examples\aicontAcquireNChan.c,for such an example.
Glenn
Applications Engineer
Glenn
(3,813 Views)
Accepted by Vadim_I
Thank you! I got the idea.
Regards, Vadim.
(3,788 Views)
