hi im having a problem installing a USB-6008 using NIKAL and NIDAQmxBase210 in a fedora 8 linux, first i was able to install the drivers but lsdaq didnt list the board, i decide to uninstall nikal and nidaqmxbase210 unfortunettly the problem get worst i was unable to unistall NIKAL, and when i try to install NIDAQmxBase210 i get the folowing error:
ERROR: make of nikal kernel module failed, not installing kernel module.
updateNIDrivers should be called again after fixing the problem.
Logging failure...
Include the file /tmp/niSystemReport.out.gz when contacting
National Instruments for support.
Installation aborted.
NI-VISA 4.0.0 could not be installed.
Please run the NI-VISA installer in the nivisa subdirectory
and then re-run this installer.
NI-VISA 4.0.0 (or later) is required for
NI-DAQmx Base 2.1.0-f0
the file with the problem is in the atachment
