07-15-2013 05:35 AM
I'm having problem with connecting my cRIO 9219. I have chassis 9112. I have an anemometer (it measures the velocity of wind) that gives the output in 0.4-30 V DC where 1mV = 1 m/s. For the anemometer I have two outputs (plus and minus connections) that I connect to pins 4 and 5 on the module. Now, I know that the anemometer is working and the VIs should be correct, too. Do I have my connections right?
07-15-2013 06:56 AM
yes!! your connections are correct.
for confirmation about the polarity connection open the DAQ assistant, select voltage, select 9219 and then channel 1.
click on the connection diagram to confirm about your wiring.
rest all seems ok.
good luck for your tests!!
