NI card digital output voltage configuration
Hello, I would like to associate my card NI 6001 to a relay card which is ordered in GPIO (notice:
https://produktinfo.conrad.com/datenblaetter/75000-99999/095843-da-01-en-STEUERKARTE_MIT_RELAIS_5V_1...)
Unfortunately, I just noticed that the Relay Relay Card has a high state of 3.7 V.
Except my NI card only delivers 3.3V digital output, which does not activate relays.
My question: Would it be possible to reconfigure the digital outputs of the Ni card to send 3.7V?
thanks in advance
(3,240 Views)
The card needs about 20mA for each input. Even if you managed to get 5V out the 6001 can't deliver the current (4mA max).
(3,144 Views)
You will need a level converter & line driver. These may need to be separate, but a quick look at the 74HCT240 indicates that it may do what you need (V input high minimum =2.0 volts, 20 mA output current per pin). Farnell have them for about 0.5 UK Pounds each, so you can afford to experiment.
Datasheet is here: http://cdn-reichelt.de/documents/datenblatt/A240/74HCT240_74HCT241_74HCT244%23STM.pdf
(3,131 Views)
A ULN280x series Darlington Transistor Arrays will also do the job.
There are a lot of relayboards which use them.
https://www.ti.com/lit/ds/symlink/uln2803a.pdf
For example: https://www.mikroe.com/relay4-board
(3,129 Views)
