PCI DIO 96 and PXI6509 error Code
Hello
I currently search an information concerning the PCI DIO96 and the PXI6509 card.
I want to detect if a pin I/O working or not on this two card. I search some information on documents and error code but nothing really conclusive.
So when we use the function "NIDAQmx.NIDAQmxCAPI.DAQmxWriteDigitalLines", the error code return by this function could or couldn't know if the I/O pin work fine ?
Best regards
(2,839 Views)
The error code sent by DAQmx driver is not really related to the state of the output lines.
If you want to diagnose your boards, you can install this application written in LabVIEW compiled in exe.
http://www.ni.com/download/daq-diagnostic-utility-2.1/2244/en/
Paolo_P
Certified TestStand Architect
Certified LabVIEW Architect
National Instruments France
(2,803 Views)
Hello Paolo
Thanks for your response I will try with this solution.
Best regards
(2,800 Views)
Hello Paolo
I try the DAQ Diagnostiq Utility with PCI DIO96 (PCI 6509) and the card is doesn't recognize by the software.
Do you know if this software work with PCI DIO96?
I don't try with PXI 6509, I will inform you when I could.
Best regards
Emilien
(2,733 Views)
