NI6501 installation name
I am develloping an application using a NI USB -6501 peripheral with .NET C#.
The NI USB-6501 is installed with the name "Dev1" so then I need to initialise a task like that
digitalOutputWriteTask = new Task();
digitalOutputWriteTask.DOChannels.CreateChannel("Dev1/Port0", "", ChannelLineGrouping.OneChannelForAllLines);
If I replace my NI USB-6501, the second one is installed with the name "Dev2". The application cannot run anymore.
Is there a software possibility to detect which 6501 is present and read its name?
Or is there a possibility to create a USB-6501 setup that always installs a peripheral with the "Dev1" name?
Thanks by advance. Regards
(4,424 Views)
You can use that function to recover the name of your device. NationalInstruments.DAQmx.DaqSystem.Local
Regards.
(4,408 Views)
Regards.
(4,408 Views)
Thanks you Mohamed.
(4,388 Views)
