convert string to physical channel input
I am using a DAQcard USB6008 to read analog voltage signals. I have written a program which outputs a string containing the channels to which devices are attached. The program executes once, then stops acquisition of all channels and outputs the string containing the channels to which devices are attached, i.e. Dev1/ai0:ai2.
How can I convert the string to the I/O physical channel format, to be able to feed it into "DAQmx Create Channel "?
(3,663 Views)
You don't have to convert the string. Just wire it directly to the physical channel input.
(3,655 Views)
Hi, that is what I tried. It does not work. I cannot wire a string directly to the physical channel of create DAQmx  channel. Could you send me an example of how you are doing it?
Thanks!
Cheers,
Rodde
(3,634 Views)
As I said, you just wire the string to the physical channel input. If you 'cannot wire a string', then you should post your code to see what might be wrong.
Message Edited by Dennis Knutson on 11-05-2007 05:24 AM
(3,630 Views)
