NI760999-01
Is it possible to get a NI760999-01 (68-pin Female connector) or similar? Are there any alternatives to the CB-68LPR? We build/use our own DAQs, I would like to avoid screw terminals if possible as they leave a lot of room for error. Putting the NI760999-01 connector on a PCB may be a good option for me.
Mark
(4,394 Views)
Hello Mark,
NI does not offer that part individually. They come with the DAQ devices and if the device has it damaged the customer has to send the device to NI for proper reparations.
In the next link you can check some PCB Mounting Connectors that NI offers:
https://www.ni.com/en/search.html?pg=1&ps=10&q=777600-01
(4,362 Views)
