NI9219
Hey there,
I have been using a NI9219 for some high resolution voltage measurements in labview.
I happen to need to look at data sensor from a sensor with 4-20 mA output. Since the 9219 is current input capabilities I was hoping to use it, however for some reason when the sensor is wired up to the 9219, the differential voltages I am reading on the other 2 channels are reading absurd values.
I am following the wiring instructions provided here:
https://www.ni.com/docs/en-US/bundle/ni-9219-getting-started/page/overview.html
in labview I have a task reading the first 3 inputs (first one is the current input and the second and third are voltage input)
am I missing something? do I need to run different tasks? or is the unit not able to combine current and voltage inputs?
thank you
(1,811 Views)
You can mix voltage and current channels in the same DAQmx task.
Here is the article - https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000PAmzSAG&l=en-US
Santhosh
Soliton Technologies
(1,790 Views)
thank you - so 2 tasks are needed.
But the fact I am using just one, does that explain why, the values reported by the read function are wrong?
(1,780 Views)
same issue with the layout proposed by the link you sent:
the voltages readings out of range as soon the current input is connected.
same behavior as I had with the project level task setup, in which I had the internal resistor selected.
I realized that I don't have the internal resistor set up right now, so I will try that next.
(1,767 Views)
same result with the internal resistor selected. I will try external resistor next I suppose. It does feel like a hardware problem to me.
(1,760 Views)
