NI9230 and NI9234 disconnect from cDAQ9181
Hi, I have several installations on the field where I'm experiencing issues with NI9234 or NI9230 modules coupled with cDAQ9181. These systems are installed in end line test machines for motors. Among the other tests, surge and hipot instruments are mounted on these machines. The NI923x are used to acquire vibration signals. The issue I have is that sometimes (in some circumstances, very often) the connection with the chassis goes down. When going to the MAX I see the NI923x in error or in gray. To restore, I have to unreserve the chassis and self test it. Obviously, this is not acceptable in an industrial machine. I tried to add an overvoltage suppressor done with 2x 15V zener diodes in anti-series in the accelerometer inputs, but it doesn't solve the problem. Any suggestion? If I don't manage to solve I have to abandon NI for my industrial applications. Tnx..
(1,205 Views)
This is a good topic to talk about with NI Support.
Since this is your first post, I would like to set expectations that this is a discussion forum for NI users and not an official NI communication method. We are NI product users like you're and we help each other based on experiences. Occasionally NI employees monitor some topics and provide solutions but are not guaranteed. If you need official support, please reach out to NI Support.
Santhosh
Soliton Technologies
(1,201 Views)
Thank you. I tried to get in touch with NI support for this issue but I got no solutions. The only answer was to go to MAX and reset from them, that is of course not a solution. Let's see if other users managed to solve this kind of issue. Tnx
(1,197 Views)
