Multifunction DAQ
NIDAQ-9.1.1
For compatibilities issues. I need to install, NIDAQ 9.1.1 on a XP machine.
I downloaded NIDAQ911f0Config.zip (an also tried by using the downloader), but I cannot
unzip the file.
For example I get:
Archive:  NIDAQ911f0Config.zip
  End-of-central-directory signature not found.  Either this file is not
  a zipfile, or it constitutes one disk of a multi-part archive.  In the
  latter case the central directory and zipfile comment will be found on
  the last disk(s) of this archive.
unzip:  cannot find zipfile directory in one of NIDAQ911f0Config.zip or
        NIDAQ911f0Config.zip.zip, and cannot find NIDAQ911f0Config.zip.ZIP, period.
Could you check the archive and upload a new one?
Thank.
(3,484 Views)
I just did it with WinRAR(eval) on my machine from this location http://joule.ni.com/nidu/cds/view/p/id/2035/lang/en
What zip software are you using?
(3,478 Views)
Winzip.
I am going to install winrar
(3,472 Views)
Accepted by patrick.dupre
Finally, I installed:  NIDAQ911f0.exe (from the ftp server)
(3,463 Views)
