NIDAQ RDA on Windows Mobile 6?
I'm having problems working out what you can do with a PDA running Windows Mobile 6 (CE/Pocket PC etc) and a USB ADC card. I've had a look around the website and I've downloaded NIDAQ mx base and a Windows mobile emulator but I've not got very far..
Is it possible to access the ADC via remote device access? Ie, can I access the ADC connected to the PDA from a networked PC running XP?
If not, what are the options for running code to run on the PDA? Do I have to run Labview or can I write some code in Visual Basic, C etc?
[If I've missed a document that explains all this, do point me in the right direction.]
simon
(3,061 Views)
Hi Simon,
If you are interested in running any LabVIEW application on the PDA, then all you need is the LabVIEW Mobile Module. Before I can suggest anything for your data acquisition, what sort of USB ADC do you have? Also, do you have LabVIEW installed on your host machine? If so, what version do you have on there?
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,044 Views)
