NIDAQmx programmatically check if device available C Code
I am writing C code using NI-DAQmx 8.6
Can you please let me know how to programmatically check if a device is accessible or not. My device is NI USB 6221.
I found the following API but these don't tell if device is connected and accessible whereas on the device list of measurement and automation studio, we can immediately see if a device is connected from its icon.
uInt32 productNumber=0;
DAQmxGetDeviceAttribute(device,DAQmx_Dev_IsSimulated ,&productNumber);
 //productNumber is set 1 if device is simulated.
DAQmxGetDeviceAttribute(device,DAQmx_Dev_SerialNum ,&productNumber);
// returns the serial number of the device
DAQmxGetDeviceAttribute(device,DAQmx_Dev_ProductNum ,&productNumber);
// for NI USB 6221 it returns 0x72dc
What is the API call to check if device is connected or not?
Hasan Ayaz
PhD Candidate
Biomedical Engineering
(3,456 Views)
Hi Hasan,
Thanks for contacting National Instruments.  The information you are looking for is a property of the system, which may be why you had trouble finding the correct function.  You can use the DAQmxGetSysDevNames function to get a full list of DAQmx devices that are installed on your system (same as what would appear under NI-DAQmx Devices in Measurement and Automation Explorer).
Best Regards
Hani R.
(3,437 Views)
Dear Hani,
Thank you for your reply. I wish the NI-DAQmx documentation was more exhaustive. In any case, thank you for the information.
Sincerely,
Hasan
(3,429 Views)
