SubVI "DAQmx.vi': required input 'task/channels in' is not wired error
Trying to read multiple data samples from multiple channels using DAQmx, I keep getting the error;
I have nothing to wire it to.
Thank you,
James-
(3,190 Views)
You have to have something. Either a task that you've created in MAX or a task that you've created with the DAQmx Create Channel. Etiher one can be a constatn or a front panel control. If you have created a task in MAX, simply right click on the task input and select Create Constant. You can click on the constant and view existing tasks or browse and create a new one.
(3,181 Views)
I figured it out...
Index array data out was not configured for waveforms.
Thank you
James-
(3,176 Views)
