 dudenukem
			dudenukem
			09-18-2018 03:58 AM
I have a missing DLL during the NIDAQmx installation on WIndows 7. Is there anyway to find the DLL name? or another solution?
The SYSTEM properties and the Error message are in the attached images.
Thanks!
 Tepig
			Tepig
			09-18-2018 06:33 AM
09-18-2018 09:20 AM
No AntiVirus; Checksum checked fine (see attachment). Tried also with the zipped version to no avail.
 Tepig
			Tepig
			09-18-2018 07:38 PM
Excuse me, do you want to install DAQmx full driver or runtime?
It seems that you are trying to install runtime version.
If you need full, try this one.
09-19-2018 02:45 AM
Yes I tried with NIDAQ1800f1 (as recommended by you) and with that NIDAQ1810f1. (checksum MD5 verified...)
Same problem. During start-up I have nierserver ERROR (see attachmenet).
SOmehow windows said that nirpc.dll was missing but I did add it. There is something else missing ;).
09-19-2018 07:55 AM
Obviously something is crashing.
There is a DeviceMonitor.exe.2544.dmp
How can we open it? Where are the logs? How can we check what is missing?
09-20-2018 10:03 AM
Some more information about the problems here:
rror -125530! An error occurred while installing the MSI at 'pciBrdI64.msi'. There is a problem with this Windows Installer package. A DLL required for this install to complete could not be run. Contact your support personnel or package vendor.
Details:
MsiInstallProduct returned 1603.
An error occurred in OnTransactionStep for transaction type 'install'.
Error Context:
NIPkg::Agents::WinInstall::Installer::Install: Installing a package
NIPkg::Agents::WinInstall::Installer::InstallWIAPackage: Installing a WIA package
 nyc_(is_out_of_
			nyc_(is_out_of_09-20-2018 10:35 AM
I'd try installing on another PC.
