NationalInstruments. common dll version 8.7.35.131
Hello
I am using Visual Studio 2010, and I am trying to access  The digial ports on my NI USB-6210.
below I have C# code.  Trying to access the daq.  It is simple, but I can't use any NI device due to the dll that I have.
I have version 9.0.35.6  I would think that this would work with the previous versions for backward capatibility.
When I try to build the program it gives me this error.
Error 2 The type 'NationalInstruments.ISynchronizeCallbacks' is defined in an assembly that is not referenced. You must add a reference to assembly 'NationalInstruments.Common, Version=8.7.35.131, Culture=neutral, PublicKeyToken=18cbae0f9955702a'.
I'm not sure if I need a different dll to reference or if there is something wrong with the dll.
Thanks.
using
(Task DRT = new Task())//Task DRT = new Task();
//find the correct port and use the default first value. DaqSystem.Local.GetPhysicalChannels(PhysicalChannelTypes.DIPort, PhysicalChannelAccess.External)[0],
DRT.DIChannels.CreateChannel(
                             "port0",
                             ChannelLineGrouping.OneChannelForAllLines);
DigitalSingleChannelReader reader = new DigitalSingleChannelReader(DRT.Stream);
int data = reader.ReadSingleSamplePortInt32();
(3,612 Views)
Accepted by ashitakaLax
It sounds like you need to add a reference to the DAQmx driver.  Here is another forum that discusses this. http://forums.ni.com/t5/Multifunction-DAQ/DAQmx-API-reference-Visual-Studio-2010-Windows-7/td-p/1408...
(3,590 Views)
(3,584 Views)
