Native format of PCI-6133?
Where do I find the natvie format of PCI-6133?  I need to know if its 8-16-32 bit integers
Message 1 of 9
(4,024 Views)
The 6133 has 14-bit ADCs. Each sample is sign extended and transferred as a signed 16-bit integer.
William Earle
National Instruments R & D | Staff Software Engineer | DAQ Software
Message 2 of 9
(4,002 Views)
Soi the DAQmxReadBinaryI16 should give me the raw value as read from the device
Message 3 of 9
(3,993 Views)
Hi boilermaker74,
That is correct. You can also use DAQmxReadAnalogF64 to get scaled values instead (for example, if you used DAQmxCreateAIVoltageChan, the data for that channel will be translated from raw ADC codes to volts).
William Earle
Message 4 of 9
(3,987 Views)
I would like to read the scalar value but the code I am updateing using raw counts.  Just out curiousity when I do a
DAQmxGetReadRawDataWidth it returns 4, so wouldn't that make the raw data 32 bit?
Message 5 of 9
(3,979 Views)
Hi boilermaker74,
Just to be clear, what subsystem are you calling DAQmxGetReadRawDataWidth for? Counters, Analog Input, Analog Output, or Digitial I/O?
William Earle
Message 6 of 9
(3,933 Views)
I am using the taskhandle that includes a ai voltage channels, so I am guessing it is the analog input subsystem
Message 7 of 9
(3,925 Views)
What version of DAQmx are you using? A quick test at my desk shows 2 bytes returned as the raw data width for Analog Input, which is what I would expect.
William Earle
Message 8 of 9
(3,919 Views)
I don't have access to that machine at the moment but when I get over there I will check the version
Message 9 of 9
(3,917 Views)
