Needing upgrade for (AT-MIO-16E-10) to PCI/USB, but still using my SCB-68 module
I have a old AT-MIO-16E-10 board in a computer that is being replaced. It is connected to a SCB-68 module. I'm hoping to either go to a pci or usb card to replace the AT-MIO-16E-10 board. Then I would like to reuse the SCB-68 module.
Any suggestions on what cards would be the best replacement?
Matt
Message 1 of 8
(3,334 Views)
Oh and I will be using LabView 7.1 to run this card.
Message 2 of 8
(3,332 Views)
Matthew,
You might consider an M Series PCI Device. Those boards will interface well with the SCB-68. However, you will need a different cable. Take a look at this site:
M Series Multifunction DAQ -- the Next Generation
http://sine.ni.com/nips/cds/view/p/lang/en/nid/14114
As for USB devices, there aren't any that will interface well with the SCB-68, however, most have built-in terminals (Like the DAQPad 6015/6016. Check out this site:
USB Data Acquisition
http://www.ni.com/dataacquisition/usb/
-Alan A.
Message 3 of 8
(3,321 Views)
I found the NI PCI-6023E model to have all of the specifications I was looking for. When comparing the cables required to connect the SCB-68 to the card, it looks like I would use the same cable. I looked through the datasheets and I couldn't find anything that might suggest the cable to be different. Could this be the case?
Matt
Message 4 of 8
(3,311 Views)
What cable do you have?
Message 5 of 8
(3,309 Views)
I take that back. After looking a little deeper into the card I would need. I found that the "NI PCI-6221 M Series" is a good fit. It does require the SHC68-68-EPM cable which I don't have.
Thank you for your help,
Matt
Message 6 of 8
(3,305 Views)
I have the SH68-68-EP cable.
Message 7 of 8
(3,305 Views)
You are absolutely right!
-Alan A.
Message 8 of 8
(3,291 Views)
