03-08-2005 07:03 AM
03-08-2005 08:31 AM
03-09-2005
11:33 AM
- last edited on
11-11-2025
03:57 PM
by
Content Cleaner
Are you trying to generate two finite pulse trains, or are you trying to generate two continuous pulse trains? Which board are you using?
If you are doing finite on an MIO board, then you will run into errors because a finite pulse train actually requires both counters.
"Finite pulse trains are produced in the same manner as continuous pulse trains, except that the counter is gated so that the gate is high for exactly the length of time it takes to generate the required number of pulses, then the gate falls low and no pulses are generated. Finite pulse trains require a second counter"
Taken from Generating a Pulse Train with a Counter
However, if you are just doing two continuous pulse trains you shouldn't have a problem from a hardware standpoint.
03-09-2005 12:56 PM
03-09-2005 03:55 PM
03-10-2005 11:33 AM
