New to LV. How can I control multiple digital outputs?
Hello-
I'm new to LV and overwhelmed by its capabilities. I'm using the 6229 card along with the TBX-68 board. I want to control 5 DO's (+5v) on the TBX-68 which will tie to external transistors which will turn on/off external relays. What is the easiest way to approach this? Any suggested tutorials? Thank you in advance.
Chris
(2,749 Views)
I would suggest using the DAQ Assistant. This should be able to get you up and running quickly. Or...you could look at the examples which ship with DAQmx. They will also be able to provide you a good starting point.
StuartG
(2,738 Views)
